Might be wrist-pin knock???
Old Feb 19, 2006 | 07:31 PM
Bode71's Avatar
Bode71
I have a 1990 F-150 with a 302 and auto, when I start it it has a very faint knock coming from the engine, it isn't rod or main bearings and it disappears when I put it in gear. I have been told it is wrist-pins and not to worry about it, It's not my main truck but I use it for hauling wood and my 4-wheeler, and other things that require that type of thing. I also like it alot. Any ideas would be appreciated.
Thanks,
Bode71
Old Feb 19, 2006 | 10:51 PM
rkcarguy's Avatar
rkcarguy
Check your flexplate bolts they may be loose and causing the noise until put into gear. If you can't then something is wrong with your engine. Use a long screwdriver to your ear and find where the noise is from.
Old Feb 20, 2006 | 07:09 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Bode to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
