Replacing a Fender
Old Feb 19, 2006 | 06:38 PM
oojbearoo's Avatar
oojbearoo
Replacing a Fender
i have a 95 Xlt i need to replace passanger front Fender Ive replaced 2 Fenders both drivers side tho so the only thing i see thats difrent is the antenna so how do i disconnect it so i can remove the fender THANKS
Old Feb 20, 2006 | 05:38 AM
marragtop's Avatar
marragtop
I would think that if you take the inner fenderwell out, you should be able to get to the antenna, or at least be able to unbolt and pull the fender off far enough to access the antenna.
Old Feb 21, 2006 | 12:14 PM
Gil Chesterton's Avatar
Gil Chesterton
What a stupid design on the 95. My Gen1 Explorers have the antenna mounted on the cross-over body section above the hood. I wonder why they changed it on the Gen2. Pain in the behind.
