I think I broke something
Old Feb 19, 2006 | 06:38 PM
Shaneb75's Avatar
Shaneb75
Strokin Okie
Thumbs down I think I broke something
I was playing in the snow yesterday in my 72 f-100. I rebuilt the 360 about a year ago. Was running great, then just stopped running. Rotor is not turning, and rocker arm assembly not rocking[img]images/icons/icon10.gif[/img].
I have not had a chance to haul it home to take a look. What most likely happened? Can you snap a cam in half??
Old Feb 19, 2006 | 06:41 PM
workingdog's Avatar
workingdog
Timing chain?
Old Feb 19, 2006 | 07:05 PM
Shaneb75's Avatar
Shaneb75
Strokin Okie
Well, all that is new... If the chain broke, wouldn't you think it was a defective part?
Old Feb 19, 2006 | 07:26 PM
AnOldDog's Avatar
AnOldDog
If you put a wrench on the crankshaft cap nut. spin it around, and the rocker arms don't move, sounds a lot like the timing chain kit to me. It could be one of the cheap $20.00 timing chain sets and you stripped out the gears or snapped the single link chain.
Hopefully, you didn't do much additional damage.
Old Feb 19, 2006 | 07:41 PM
JARedman's Avatar
JARedman
I agree with broken timing chain and or gear. The stock sets are sad as are quite a few aftermaket sets. If you rotate the crank(disconnect battery first, and use appropriate socket with care) and the valvetrain doesn't move or distributer,put money on the chain or gears. If you weren't over revving , and it is a brocken chain or gear, you will probably be ok. Good luck! Jamie
Old Feb 19, 2006 | 08:33 PM
Redmanbob's Avatar
Redmanbob
has to be timing chain, as the valve train would still work if the distributor gear pin sheared. crank key slipped out ? Cam chain gear drive pin out of position. ?
Old Feb 19, 2006 | 09:50 PM
FalconStng's Avatar
FalconStng
I agree it's most likely in the timing chain or gear. I have seen cams break in other motors before but never and FE. If it broke right at the gear then you'd loose both the distributer and valve train. I seriously doubt this is what happened though. Either way you're going to have to pull the front of the engine down. Did the timing chain gear have plastic teeth?
Good Luck!
Tracy
Good Luck!
Tracy
Old Feb 19, 2006 | 10:48 PM
seetwisted's Avatar
seetwisted
If you mistakenly got a soft metal keeper on the drive shaft nose for the timing gear, it may have shiered...and what you all said about the chain ,When you pull the timing cover,will you upgrade any thing while you're there?
Old Feb 20, 2006 | 05:29 PM
Shaneb75's Avatar
Shaneb75
Strokin Okie
I am hoping for something easy.... I will be hauling it home when the snow melts off.
About the over reving scenario, I'm afraid to admit that might be the case. When I get her fix I will be more careful. I did take a look under that valve covers and all looks fine there. I will give you all an update when I tear it down.
Thanks again!<o></o>
Old Feb 21, 2006 | 01:19 PM
tastyklair's Avatar
tastyklair
Yes timing chain. How have you made out?
Old Feb 21, 2006 | 08:46 PM
Shaneb75's Avatar
Shaneb75
Strokin Okie
I will be bringing it home Thurday after work, and breaking it down Saturday morning. Depending on whats wrong I may go ahead an fix it. If its major I will wait. But I will give you all an update as soon as I know something.
Old Feb 26, 2006 | 09:52 PM
Shaneb75's Avatar
Shaneb75
Strokin Okie
Got it fixed, and running great. When I rebuilt the engine I thought to myself what keeps this pin from coming out? But never acted on my thought. Until now that is. I feel like an idiot...... But no damage done.
Thank you all for your input....
Old Feb 26, 2006 | 11:11 PM
AnOldDog's Avatar
AnOldDog
lucky no harm done. Ok, now you can have fun.
Old Feb 27, 2006 | 09:56 AM
Redmanbob's Avatar
Redmanbob
And you wanted an electric fuel pump.. see the down side to this LOL
