Ive got an 06 screw 4x4 and am looking at the different leveling kits. I found the EZ-LIFT kit on ebay and ive seen others talking about autospring kits.
I checked with 4wheel parts and they said there leveling kit, shocks and alignment was around 450$
Looking to level the truck, but not looking to drop 450 bucks!!!!!
Go to ebay and buy a AutoSprings leveling kit. i got it for $100 shipped. The installation is very very easy. You can easily do it yourself if you are patient. And you will DEF need a whell alignment. Your toe will be so far off that your tires will be eaten alive by the pavement. Good luck
P.S. You can get either the 2" or the 2.5". I have done hours of researching and have found that the 2" leveling kit still left a rake of .5". So I opted for the 2.5 and it is PERFECTLY leveled.
both EZ LIFT and Autosprings install ontop of your strut. Therefore, you dont need to replace anything. When I received the package from EZLIFT, nuts and bolts were missing and the package was lost for about a week. When I got it, the package was destroyed. Go with autosprings. EZLift is aluminum and Autosprings is metal. Much stronger and more reliable. Take it from someone who had both in their hands.
