351W crank pulley
Old Feb 19, 2006 | 05:45 PM
McLeod's Avatar
McLeod
351W crank pulley
I have a 3 sheave,3 bolt 351W crank pulley (part #C9ZE-C312-B) off of a 69 stang.
Because of the tight conditions in the early Bronco this is installed in, I need to get rid of the outermost sheave so the fan will clear the crank. (2.25" between the 4 core radiator and the waterpump flange)
The crank pulley appears to be constructed of three separate pieces.
My question is: Does anyone know if it is possible to separate the individual components of the crank pulley without destroying them or should I just have it turned on a lathe to "lighten" it up?
Old Feb 20, 2006 | 09:42 AM
TigerDan's Avatar
TigerDan
They generally are separate pulleys stacked together and spot welded...but what tough little welds! I've tried to pry them apart and mangled them in the process. If you have access to a lathe then yes, that would be a good way to go about it. You could cut that outermost pulley out from inside, at the hub.
Old Feb 20, 2006 | 12:16 PM
McLeod's Avatar
McLeod
The spot welds are what I was afraid of. Probably should turn in lathe to remove the surplus sheave unless I can locate a 2 sheave with the same offset/alignment.
Ebay has a guy trying to get $30 for the 3 sheave pulley and that is why I'm hesitant to destroy the one I have.
Thanks!
Regards
Ken
Old Feb 20, 2006 | 06:50 PM
TigerDan's Avatar
TigerDan
Yeah, I can't blame you there. I hate to chop up a vintage part that may turn out to be valuable.
With all the different accessory offerings over the years, you should be able to find a two-groove pulley without too much trouble.
LipschitzWrath
Jul 21, 2015 02:08 PM
Becky_is_a_66
20
Jan 28, 2014 10:04 AM
P38fighter
Feb 12, 2012 03:41 PM
HT32BSX115
21
Jun 8, 2005 04:43 PM
therigwelder
Jun 16, 2001 11:16 AM
