97 EXP 5.0 Left Headlight problem
Old Feb 19, 2006 | 12:52 PM
u42011's Avatar
u42011
I have a 97 Explorer 5.0 V8 that has a passenger side headlight problem. The drivers side headlight works fine both low and high beam. The passenger side only the high beam works. Also, the fog lights stopped working at the same time that the passenger side headlight low beam stopped working. I have replaced the bulb, and replaced the fuse and they still won't work. I have also checked the wire for the lowbeam at the headlight and nothing. I also checked and I have power going to the fuse, so the problem is somewhere between the fuse and the lamp itself.
Any other suggestions?
Old Feb 19, 2006 | 04:21 PM
bean440's Avatar
bean440
headlite
I had same problem, and it ended up being the LOM (lamp out module) that was located under the consode on my 95. It is a small black box about the size of a pack of cigarettes. I guess there was a problem with the solder connections. I remove mine and resoldered the connections and it worked!!! I think they cost about $60, Try to resolder 1st, took about 15mins total. Hope this helps!!!
Old Feb 19, 2006 | 05:10 PM
u42011's Avatar
u42011
Thank you, I will give it a try.
Old Feb 19, 2006 | 06:51 PM
u42011's Avatar
u42011
That was it. I had a broken solder joint on the LOM circuit board. Awesome!!!!!!
Old Feb 20, 2006 | 07:31 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
mechasus
Escape & Escape Hybrid
Oct 25, 2021 04:06 PM
44vulcan
Nov 27, 2015 04:37 PM
Bad Bird
Apr 9, 2012 06:38 AM
Weezman
1978 - 1996 Big Bronco
Sep 9, 2008 05:04 PM
exlmtd
Electrical Systems/Wiring
18
Nov 21, 2003 04:57 PM
