I need help, I want a F-250 or F-350 CC. Can not make my mind up. Can not decide what engine to get (6.0, V8 or V10 and do I need a 4x4. The truck will be use for daily driving and pulling my 19 ft boat and within the next two years, I would like to get a truck camper.What are the gas mileage for the 6.0, V8, V10. Thanks for a ll your help.
I had that same question also awhile back so thats why I came here. That question will start a snowball. I strongly suggest to search this site for all the answers you are looking for. My decision came by all the V10 gurus here. Also use the archives. Fredvon,captchas,monsta and wrenchtravler along with other wise ones are the ones that will guide you in your endeavor. A little effort will go a long way and prove valuable. Good luck. Almost forgot, check out the mileage tracker at the tiop of this forum.
I had the same problem before I ordered my new SD. I just wrote down the advantages and disadvantages of both, what I would be using the truck for, will the gas mileage matter as much as towing power, etc. Good luck with your decision! By the way, I picked the diesel!
yes, start reading through all the forums, it will take awhile but for that much money, its worth the investment.
to put aside the reason of just wanting; i have a diesel, but i plan on keeping it a very long time, so the extra costs will eventually pay for itself. the v10 is a capable puller with lots of power, just the gas mileage isn't near as good as the deisel and the diesel is a puller! but factor that in with the extra costs of a diesel to your preference and affordability, and my experinece in the past shows the diesel has a higher resale value than a gasser, especially over 100k miles.
as far as gas mileage goes, mine averages 18mpg on the highway, i don't tow anything so can't tell you on that. i think the v10 gets about 10-12, not sure, i never owned one. good luck!
I recently faced this same situation. My 90 Ranger was getting mighty tired. I wanted an F250 SD with 4WD/auto trans. I also pull a boat (18' jet) and wanted a daily driver as well. I considered an F150, but really wanted the F250. Then I was faced with power. I was going to look at one with a 5.4, but ran across one with a V10, and the price was very "right". I test drove it, and bought it on the spot. I am very happy with it (so far), lol.
Oh- and I can't remember the number of times I have needed 4x4 pulling out of launch ramps, and in the snow.
The Diesel is louder at idle (at speed its not much different) Some like the sound, some don't.
Gas Mileage is better in a diesel, sometimes a lot better. (but diesel is more expensive right now, so that's probably a wash)
The Diesel is much more powerful, BUT because of the turbo lag, 'driveability' is different. In a gasser, from a dead stop you step on the gas it LEAPS forward. In a diesel, from a dead stop you step on the gas and the truck goes but the power curve doesn't hit for a couple seconds (while the turbo spools up) Once the turbo spools up then it REALLY pulls like a sports car. For me the turbo lag affects me most when I'm trying to dart across an intersection between traffic. Its harder to do with a diesel because of the turbo lag.
On the positive side... The diesel has so much power and so much torque, that when you are cruising down the highway at 55 or 65 and you push the pedal to the metal. I just GOES instantly. No downshift, just power.
Most say the V8 is too doggy for a SD because of the mass that the engine has to move so I would leave that out of the decision. What kind of "daily driving" will you be doing (how far is your drive to work, where do you live, do you want the hassle of the diesel maintenance)? To give you a completely informative answer, we need some more information. The info you gave could make you swing either way but certain things like altitude and climate can really swing a decision one way or another. So basically, be VERY detailed in what you will use this truck for.
The gasser has more horsepower, so the gasser has more power The diesel has more torque; however, torque is a function of gearing and the gasser will be available with lower gearing (SRW), so the difference is less than most people think.
The weight of the gasser is less, so the gasser will have a higher payload capacity, and the towing capacity will be the same (in some cases higher with the gasser, with auto trans, unless you get the "tow boss F350" package).
The daily drive to work will be approx 15 to 30 min that's all interstate highway driving. We live in Virginia. The truck will be used to pull my 19 ft boat at a weight of approx 2000 lbs. In about two years I would like to get a truck camper. It will be a truck that I will have for a long time.
Towing capacity may be the same on paper...that's about it. Bottom line, if you want a "puller" while all the same getting good gas mileage go with diesel. If gas mileage is not a concern and the extra $5K is, then go gas.
... if you want a "puller" while all the same getting good gas mileage go with diesel.
Don't you have to have a gasser to get good gas mileage, and a diesel to get good diesel mileage
Also, on paper is very important sometimes, especially if getting a camper or trailer that may be near the payload/towing capacity... in order to be "legal" anyway. I just wanted to original poster to realize some aspect that some people don't think of prior to purchase and find out later, the hard way.
Go to the V10 forum or 6.0 forum to find the exact answers to which powertrain you should get. This forum is good but get feedback from the exact forums. Good luck cjr.
I think that you would be better off with a V10. Since you live in virginia, high elevations will not be an issue therefore forced induction from the diesel will not be needed. Your daily commute really isnt long enough that a diesel would be more beneficial and virginia can get pretty cold during the winter, which would give a plus to the gasser since extension cords will not be needed. A V8 will do the work you want to do with ease but if you want extra power, go V10.
Gary
Also, take a look at fuel prices around your area, specifically regular gas and diesel. That will be another major factor as MPG could become a washout.
