1989 2.9 high idle
Old Feb 19, 2006 | 10:52 AM
ddthom's Avatar
ddthom
Angry 1989 2.9 high idle
I have a 1989 Ranger 2.9L that was stalling out on me after driveing for allmost 30 miles, put heet in gas tank first time and ran great for two weeks then started doing it again this time heet did not work, Change fuel filter,pump and hanger assy.,pvc,breather filter and TPS. Now engine idles at about 1700 rpm have checked everything according Haynes/Chilton manuals but still no luck. Please Help.
Old Feb 20, 2006 | 07:35 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Feb 20, 2006 | 11:26 AM
mrshorty's Avatar
mrshorty
Lots of possibilities. Start by pulling codes and checking for vacuum leaks/vacuum hose left unplugged.
Old Feb 22, 2006 | 06:42 PM
ddthom's Avatar
ddthom
Pulled codes got 11 for koeo,and a 13 for koer, no continuios memory codes, rplaced vacuum lines to Pvc and Breather checked all others but RPM is still at 1700+ couls it be the control modual or according to my scan tool book aIntegrated vehicle speed control and if so where is it. Thank you.
Old Feb 22, 2006 | 08:36 PM
mrshorty's Avatar
mrshorty
KOER 13 is often not very diagnostic. Basically it means the idle was high during the KOER test (we already knew that).
Vacuum leaks are the most obvious cause of high idle on an EFI engine. Be absolutely certain you don't have a vacuum leak.
Check the idle air control (IAC) valve, sometimes called idle speed control (ISC). Make sure it's clean. Most of the time, a dirty IAC will cause a low/rough idle rather than a high ile.
Old May 24, 2006 | 08:32 PM
eisle89's Avatar
eisle89
Idle Air Control valve sticking ??
helocast
Feb 4, 2013 01:36 PM
udder
May 3, 2011 07:02 AM
rubberducky700
1983 - 2012 Ranger & B-Series
Mar 5, 2010 11:03 AM
dharget
24
Jun 25, 2009 04:45 PM
Mikeri
Jun 28, 2008 12:05 AM
