Sponsored by: Real Truck
2002 F-250 stops running
Old Feb 18, 2006 | 01:26 PM
Beana's Avatar
Beana
Smile 2002 F-250 stops running
My f-250 has been in shop three times for same problem. Truck just stops running for anywhere from a few seconds to several minutes. Injectors have been replaced. Does anyone else have this same problem? Thanks for the help.
Old Feb 19, 2006 | 07:15 PM
PSD Bill's Avatar
PSD Bill
Could be a lot of things - begin with a diagnostic test. Could be the CPS....
Old Feb 19, 2006 | 07:28 PM
FortyFords's Avatar
FortyFords
A little more info on your truck would help ! what engine ? what have they done at the dealer every time it was brought in?
How many miles ? what maitenance have you done ?
Did this gradually get worse over time ,does it stuter,cough or just shut down?????
Rich
Old Feb 19, 2006 | 08:00 PM
Beana's Avatar
Beana
Smile
Sorry, It has a diesel engine. Regular factory maintanence. I just have 52,000 miles. It has always started with the engine being a bit sluggish. It feels like it does not have the same amount of power, if that makes sense. The first couple of times it almost stopped running but never did. A few days later I was going about 40mph and the lights on dash came on and it had no power. I let it rest for about 10 minutes and finally started. Happened several times before tow truck got there. Last two times, lights on dash came on, lost power however never completely. 10-15 seconds with no power steering or ability to use gas, truck starts running on its own. Dealer has replaced cylinders, removed injector. Problem is very random. Never had any other problems with my truck. Thanks for your help!!
Old Feb 19, 2006 | 08:32 PM
99f350sd's Avatar
99f350sd
Can sensor is what it sounds like. I suprised they havn't replaced it.
Dick
Old Feb 19, 2006 | 09:28 PM
DD1684's Avatar
DD1684
I'd say cam position sensor.
Old Feb 20, 2006 | 08:09 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Beana to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Feb 20, 2006 | 11:28 AM
BDISCO's Avatar
BDISCO
+1 Same thing happened on '00 7.3 F250 Dealer should know about this.
