Dash/switch help
Old Feb 18, 2006 | 01:16 PM
rpenterics's Avatar
rpenterics
Dash/switch help
How do I remove the dash on my '89 F250, I need to replace my headlight switch so I can drive at night again. Thanks for the help
Old Feb 18, 2006 | 03:14 PM
gravydude's Avatar
gravydude
You need to start with pulling off the head light and window wiper switch *****. Then pull or pry off the the panel around the switches. This will panel just snaps on to the dash. After doing this you should be able to see about four or so hex screws. You should be able to see a braket that holds the two switches. Just remove the head light switch and replace with new. The hardest part of the job will be removing the connector from the switch. Sometimes the connector will be melted onto the switch. Good luck!
Old Apr 12, 2006 | 06:23 PM
rpenterics's Avatar
rpenterics
Just wanted to say thanks, got the switch replaced and back in working order ended up having to replace the dimmer switch too.
Old Apr 13, 2006 | 07:28 AM
gravydude's Avatar
gravydude
Your welcome, I only know this because I've done it twice now to my truck.
