I was changing the spark plugs out in my 82 F150 and saw the ones I was replacing have that V-notch on one of the contact points and when I went to the auto store to get some new ones, they only had the platinum ones that have the regular pin-point look, if you get my meaning. I was wondering, is there any difference in performance between the V-notch and the regular style plugs?
The difference is most likely the difference in manufactures. PLATINUMS are PLATINUMS. As long as they are the right application and heat range you should be OK.
the v notch is a scam. just like the splitfire plugs. also there is no need at all to use a plat plug in your 82. plat plugs are for waste spark ignitions only. they serve no purpose in anything else.
Platinums will also extend the plug life for non-waste spark ignitions. The main reason for double platinums (both electrodes are platinum) are due to the opposite polarity spark that half the plugs get with the waste spark ignitions.
i was reading up, and i'm confused, what is a "waste spark plug?" i always just used standard plugs from parts store, probably autolites or something...
The term is "waste spark" which refers to distributorless ignitions that fire two plugs at once. Only one pistion is coming up on tdc at a time so the other spark is wasted, or unnecessary. Typical is where you have one coil that fires two cylinders that are opposites in the firing order.
the one coil that controls two spark plugs fires on every revoultion, its the higher cylinder pressure and resistance through the plugs that determines which plug fires at each time.
I thought they both fired, need it or not. Guess I'm still not on the crest of the new wave.
They essentially do because 2 plugs are on one circuit so the electricity goes through both, but the cylinder with the most resistance gets the biggest spark, the other cylinder gets a much much weaker "waste spark", hence the name.
