Offroad & 4x4
Tls Boggers
Old Feb 17, 2006 | 08:43 PM
THEBOOGIEMAN's Avatar
THEBOOGIEMAN
Tls Boggers
Will The Tls Boggers Be Ok If I Haul 1 1/2 To 2 Tons Of Gravel?
Old Feb 17, 2006 | 08:53 PM
mark a.'s Avatar
mark a.
It should say somewhere on the sidewall how much it can safely hold.
Old Feb 17, 2006 | 08:54 PM
76 F-150 390FE's Avatar
76 F-150 390FE
what size are they?
Old Feb 17, 2006 | 10:16 PM
DaveBowman's Avatar
DaveBowman
The bigger the size the more they are rated for. Check the sidewall, it will say how much weight they are rated for at the full PSI
Old Feb 18, 2006 | 12:19 AM
fishmanndotcom's Avatar
fishmanndotcom
yea you'll be fine. just pump your tires up to max pressure and keep your speed less than 60 (less heat created the better off you'll be)
-cutts-
Old Feb 18, 2006 | 10:26 AM
THEBOOGIEMAN
33\13.50\r15, and it wont see more than 45 to 50 mph.
Old Feb 18, 2006 | 11:42 AM
monsterbaby's Avatar
monsterbaby
wait a minute when did the bogger come out as a radial tire?
Old Feb 18, 2006 | 05:29 PM
fishmanndotcom
where did you get his boggers are radials?
-cutts-
Old Feb 18, 2006 | 07:44 PM
monsterbaby
Look at the size he lists, there is an R right before the rim size which indicates radial tire
Old Feb 18, 2006 | 07:47 PM
bremen242's Avatar
bremen242
i always thought that went rim size, maybe he did too?!?
Old Feb 18, 2006 | 07:53 PM
chrono4's Avatar
chrono4
no, the are is for radial, so it would be a b 15, or however they name bias
Old Feb 18, 2006 | 09:27 PM
THEBOOGIEMAN
I was told that the r did mean rim.
Old Feb 18, 2006 | 10:08 PM
monsterbaby
Nope it means radial here is a link the explains tire sizes.
http://www.justtires.com/services/ti...fications.html
Old Feb 18, 2006 | 11:04 PM
fishmanndotcom
o ok, lol i always thoguht it meant rim!
i feel stoopid
-cutts-
Old Feb 20, 2006 | 11:45 AM
MBBFord's Avatar
MBBFord
Size 33x12.50-15LT
Ply Rating 6
Skid Depth 23/32
Tread Width 11.5
O.D. 33.2
C.S. 12.8
Rim 15x10
Max. Infla. 30
Max. Load 2205
That's all the information on the tsl Boggers for that size.
But the R means radial, and the boggers are only bias ply, no radial.
