400 Rotating torque- FYI
Old Feb 17, 2006 | 05:02 PM
TMI's Avatar
TMI
We have assembled a 400 short. No timing components, using a torque wrench it requires 25# to rotate the assembly. Badger flat top pistons, and typical moly rings set. Maybe took an extra 5# to break the assembly loose. Next we will Simtest the assembly.
Old Feb 17, 2006 | 06:38 PM
Torque1st's Avatar
Torque1st
Posting Legend
I transfered that info to my "Files"... -Thanks!
Old Feb 18, 2006 | 12:23 PM
grclark351's Avatar
grclark351
that's what i'm talkin about, sounds real good! a couple guys posted high readings required to turn, i'm worried that they may have a rod cap flipped or rods out of order/position. there's a larger chamfer on the crank side of the rod, and not so much chamfer on the rod to rod sides. an engine assembled incorrectly will try to tell you early on if you listen, it'll tell you in no uncertain terms a little later.
Old Feb 18, 2006 | 12:57 PM
cwheel's Avatar
cwheel
dumb question, but when you say "no timing components", do you mean the timing chain wasn't hooked up (ie the cam wasn't turning)?
Old Feb 18, 2006 | 02:41 PM
TMI's Avatar
TMI
This block only has the rotating assembly in it. No chain, or camshaft
