Hi Guys, please could someone advise me on the following. I am having difficulty locating the PCM in the engine compartment as it does not appear under the brake master cylinder which is located on my drivers side (your passenger side).
The PCM inside the truck is under the dash next to the passenger kick panel (which is your drivers side). If the PCM in the engine compartment is on the same side then i have the heater etc in my way.
So basically, do i have to remove the 10mm bolt (that i cannot locate) from the centre of the harness and pull apart from the PCM or can leave it and move to the next step re the installation ?. Thanks for a great site
