My turn for front end work
Old Feb 17, 2006 | 01:01 PM
Fords4Me's Avatar
Fords4Me
There I was, cursing the stock springs for not having enough droop to allow placement of the top of the new Rancho into it's upper mount last night, when I leaned on the driver's front wheel and it went "thunk". Found about a 1/4 inch or less travel in the top of the tire when the top is pushed on. No alignment problems, no grinding bearing sounds. How much movement is too much for the bearings and/or ball joints? I knew one day i'd have to deal with yes yet another design issue, but not yet. 65k on the clock. Maybe there's enough left to get to spring?
Old Feb 23, 2006 | 11:34 AM
Fords4Me's Avatar
Fords4Me
Ball Joint(s).
Old Feb 23, 2006 | 12:08 PM
Joe98684's Avatar
Joe98684
Sounds to me like you need to replace the bearings. This is a pretty spendy job on the Ex as it is a sealed bearing unit. You have to replace the whole hub assembly. I had to replace mine and never had any warnings really when mine went out, no alignment problems.. no clunking... no bearing noise. The only way I ended up finding out there was a problem was when it got so sloppy that the wheel tipped in and the brake calipers started digging in to the outer edge of the rotors.. too late by then, so new rotors... new brakes... new bearings. I should have done it myself, but there was no way I could make the time for it and had to have the vehicle for a upcoming trip... lots of $$$
Old Feb 23, 2006 | 01:12 PM
Fords4Me's Avatar
Fords4Me
And then there's the conversion kit.
http://www.dynatrac.com/products_freespin_ford.html
If i'm really gunna keep it for the next 200k Mi nothing else makes good sense.
Old Feb 23, 2006 | 01:16 PM
Joe98684's Avatar
Joe98684
Wish I would have known about this BEFORE mine was replaced. For the money I spent, I could have this! Ever happens again and I know what my next purchase would be
Old Feb 23, 2006 | 01:22 PM
Fords4Me's Avatar
Fords4Me
I hear ya joe, but man we're talking about dropping $2k on a vehicle with 65k Mi for front end work (just for parts) between the poor design spindles and non-greasable ball joints. I think these trucks should have come with a lemon press. Dont even mention 4r100 or sagging springs.
Old Feb 23, 2006 | 01:30 PM
Downriver Thunder's Avatar
Downriver Thunder
Mine are greasable.
Old Feb 23, 2006 | 01:32 PM
Joe98684's Avatar
Joe98684
I totally agree with you there. Is your Ex still covered under any warranty? Mine is a little older than yours with a few more miles (98,000). I would expect that at that many miles that you would need to service and repack your bearings, but in their infinate wisdom... they decide to design them so you CAN'T do that! Two grand is not much when you compare to the alternative. I paid $1800 to the stealership for both hub assemblies, new rotors and pads installed. I was just sick to have to do that, but had no choice do to time constraints. If I had time.. and could do it all over again... I would go with the Dynatrac, even at $2 grand
Old Feb 23, 2006 | 01:43 PM
cooper's Avatar
cooper
Is the " clunking " you're referring to the clunk you feel when braking? It feels like its just under the drivers left foot? I have heard a clunk in that area for sometime but also read there was some mystery clunk that could not be determined on some vehicles..
Old Feb 23, 2006 | 01:56 PM
Fords4Me's Avatar
Fords4Me
Originally Posted by Downriver Thunder
Mine are greasable.
Stock? Did you buy it Used? What year?
The clunk was when I leaned on the top of the tire when it was off the ground and it moved inwards.
Old Feb 26, 2006 | 10:41 PM
RDRAY's Avatar
RDRAY
For the price of the conversion kit, I could replace both sides twice and still come out ahead. My left hub assembly went out last summer. Cost to replace was $435.00 installed. If I'd known how easy the assembly was going to be, I'd have done it myself and saved more.
Old Feb 27, 2006 | 06:31 AM
Fords4Me's Avatar
Fords4Me
381 for the NAPA hub. Took about 2 hours, one of which was dealing with the lock-tite on the studs that hold the assembly on the knuckle. I cant believe how bad it was and had no "rumble" like bearings used to.
Old Feb 27, 2006 | 02:50 PM
FordandCaravellz's Avatar
FordandCaravellz
My hub assembly decided to go out this weekend on a trip from Louisville, Ky to Cinncinatti. Luckaily we made it withing a few miles of our destination. At first I was sure that the problem was with the brake system since my ABS light came on. After taking off the wheel to inspect the damage I noticed that the hub had alot of play to it. My rotor was grinding against the caliper making the metal on metal sound. I found the part for around 350 beans. I was lucky to have a friend install it for me. After watching him I will do the next one if nessasary.
sfc2001
22
May 9, 2023 02:36 PM
ktm4012
Jun 16, 2016 03:15 AM
ktm4012
Jun 5, 2016 07:49 PM
OldWoodsDiesel
Oct 22, 2012 07:45 AM
