Cheap Battery
Old Feb 17, 2006 | 08:18 AM
hart2345's Avatar
hart2345
Cheap Battery
I had to buy a cheap battery for my 95 F150 5.0. Now trans. shifts hard sometimes and guages are not steady. I have been told even if the truck is starting fine the battery can cause these problems if too small. Does anyone know if this is true?
Old Feb 17, 2006 | 08:22 AM
s8whiskey's Avatar
s8whiskey
A low battery may do it so would a bad ground alot of things might do it. When you say not steady which gauges do it?
Old Feb 17, 2006 | 08:25 AM
hart2345's Avatar
hart2345
The voltage guage and the speedo. I am pretty sure the battery is causing this but the trans I am not sure of.
Old Feb 17, 2006 | 08:27 AM
s8whiskey's Avatar
s8whiskey
If the speedo does it check your VSS and when was the last time you flushed the diff? For the volt gauge check you engine grounds and the terminal connections and your alt connections.
Old Feb 17, 2006 | 08:35 AM
hart2345's Avatar
hart2345
Thanks
Will do this week end
Old Feb 17, 2006 | 10:27 AM
quicklook2's Avatar
quicklook2
i doubt it is the battery being inexpensive.
reset computer.
try charging the battery and see if that makes a difference.
