engine skipping
Old Feb 17, 2006 | 06:50 AM
TractorM3's Avatar
TractorM3
engine skipping
well u got an issue that isnt big but i dont want to let it go un-attened. i always let my engine warm up for a period now that the weather is cold here but the engine skips slightly. when its in first to third gear i can feel like one or two pulses during exdceleration. it will dip then recover. it wont like be bad but its enough so you can feel it driving. i did a basic tune up about 14k ago. i use mid to high grade gas. it also shakes a bit during idle. maybe injectors? or i was thinking fuel filter? its a 94 f150 300/4.9 EFI with 139k
Old Feb 17, 2006 | 03:54 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Feb 18, 2006 | 10:47 PM
bks90F150's Avatar
bks90F150
When you are idleing, it is normal for the 300 to have a little shake. From what I've learned from other guys, The 300 shakes a little at idle because it is a lean-running engine due to emissions standards. If you were to change the air/fuel ratio, the 300 would run a lot smoother at idle.
Old Feb 18, 2006 | 10:48 PM
brosko80's Avatar
brosko80
that would explain my white spark plugs.
