brake problems
Old Feb 16, 2006 | 09:08 PM
Bodo's Avatar
Bodo
brake problems
we had a huge snow storm up here in northern michigan. You all know what that means, a broken truck. I was coming home from the womans house and lost feeling in the brakes. Then the brake light came on. I pulled over and checked the resevour and it was still full, and the ground was clean. I then proceded to drive the truck home. The brake light would come on and off. I kept pumping the brakes and got better feel while the light was off, but it didn't last long before the light came back on and i lost all brakes. I think it's a booster. what else could it be. the master is about a year old, and the booster was dry. I've never replaced a booster, and will not have a mechanic do it because i'm getting rid of this truck soon and don't want to put money into it. I forgot to add it's a 1979 ford F 150 4 speed 4x4 with a 300 I6
Old Feb 16, 2006 | 09:15 PM
Mil1ion's Avatar
Mil1ion
The light only comes on if there is an unequal amount of pressure in the front & rear brake line.
If you don't have any fluid loss,That M/C is shot and needs replacing.
Get one that's been made with a Stainless Steel Sleeve.
