temp controls stay hot. help!
Old Feb 16, 2006 | 08:06 PM
tsi9973's Avatar
tsi9973
hey guys i have a 88 f150 5.0 the problem is the heat selector will not go to cold the lever springs back to hot. i can move the lever to cold but when i let go it just goes back to hot. what could be causing this and how do i fix it?
Old Feb 16, 2006 | 08:40 PM
Ultramagdan's Avatar
Ultramagdan
That lever should be going to your blend door, which lets outside air in. When you move it to cold, does the temp change? You will probably need to get in the dash and see what has hung up.
Old Feb 17, 2006 | 07:38 PM
tsi9973's Avatar
tsi9973
no the temp stays hot i even put a small screw to keep it cold and it stays hot. what is going on?
Old Feb 18, 2006 | 03:47 PM
Bdox's Avatar
Bdox
Sounds like that cable mounting came loose.
Old Feb 19, 2006 | 08:21 AM
tsi9973's Avatar
tsi9973
is the cable behind the dash? do i have to take the dash apart? or can i get to it from the engine compartment?
Old Feb 19, 2006 | 08:50 AM
Ultramagdan
You will need to get behind the dash.
Old Feb 19, 2006 | 02:56 PM
tsi9973's Avatar
tsi9973
o.k thanks.
seadoo01
1983 - 2012 Ranger & B-Series
Feb 12, 2016 07:32 AM
davran
Dec 27, 2015 02:21 PM
cr9c1
Jan 1, 2007 01:57 PM
honeyCANdew
Apr 13, 2005 12:04 AM
