In case my other post never makes it thru, Google: 9145 9005 swap
It should be the first result (it's on a site along the lines of, but inferior to, FTE). It will tell you how to use higher wattage 9005/9006 bulbs instead of the low watt 9145's. Go ahead and read it all including comments. For informational purposes only!
