crank pulley
Old Feb 16, 2006 | 11:57 AM
towtruck's Avatar
towtruck
crank pulley
I have two questions.. One, from what I have read a 351w crank pulley will fit a 351m/400. Is this correct? My stock pulley is bent and I can't find a stock replacment. Two, I just bought a Edelbrock Performer 400 intake off of eBay. Do I need a different gasket for it?
Thanks
Greg
Old Feb 19, 2006 | 08:30 PM
sparky69's Avatar
sparky69
not sure about the 351w pulley, but i've never heard of these being interchangable with the 351m/400. if you are talking about the "turkey pan" type intake gasket i would recommend getting a new one. the metal will crush when torqued down, and reusing the old one is just asking for trouble (air leaks). they are kind of expensive tho... like $30-40.
Old Feb 22, 2006 | 01:31 PM
tastyklair's Avatar
tastyklair
I you use a stock pulley they are different. If you get an aftermarket they are usually the same, just check the listing in the book.
