Power Steering Leak
Old Feb 16, 2006 | 11:34 AM
cnajp's Avatar
cnajp
Power Steering Leak
I have a 1994 Ford Explorer, Eddie Bauer....with a 4.0 engine. It has quite high mileage on the engine. I am having a problem with the power steering leaking. The cap on the power steering is quite loose. fluid has leaked from the cap, ran down the hoses, and leaks on the ground. It isn't a very large leak, but since it comes out from the top of the actual pump itself, does that mean that the pressure and return line(s) of the pump may be clogged? The fluid looks quite dark, but the car steers really well! I am not sure what to do, but I went ahead and bought a new cap, and new hoses for the power steering. I was not sure if I needed to put them on or not, before I got an opinion from this site.
Thanks very much!
-J-
Old Feb 16, 2006 | 06:03 PM
JerrySimm's Avatar
JerrySimm
Are you sure it didn't simply have too much fluid in it? When cold, if it's filled above the cold fill line, it will expand enough to leak out of the cap.
Old Feb 17, 2006 | 05:37 AM
marragtop's Avatar
marragtop
I would degrease everything, put the new cap on, make sure the old lines are tight, and make sure the level is correct. Drive it and see what happens. I wouldn't put the new lines on unless the old ones look bad, or you still have a problem.
phoneman91
Feb 27, 2014 04:08 PM
fx8racer
1997 - 2003 F150
May 10, 2010 07:53 PM
davdogg39
1978 - 1996 Big Bronco
Jan 29, 2006 08:15 PM
swhite005
Jul 12, 2005 09:40 PM
