ckp sensor
Old Feb 14, 2006 | 08:12 PM
indyjim's Avatar
indyjim
Angry ckp sensor
Hello all,my question-ia there any to test these sensors to see if there good? as i have been having on run no spark problems, i have spent many$$$$ on thisand still not running.anyhow today it started up was running fine ,checking wires and things ,got under the truck touched the ckp sensor truck shut down fired her up again touched the sensor again truck shuts down,whats up with that? any help with this????[img]images/icons/icon8.gif[/img]
Old Feb 14, 2006 | 11:31 PM
savagefan's Avatar
savagefan
Bend the pins a little and reconnect and retry, check your other post for a jiggy on this and good luck.
Old Feb 15, 2006 | 06:35 AM
Franklin2's Avatar
Franklin2
What is a ckp sensor? What year truck and what size engine?
Old Feb 15, 2006 | 06:54 AM
subford's Avatar
subford
I he is talking about the Crankshaft Position Sensor (CKP) on a 4.0 1993 Ranger.
Old Feb 15, 2006 | 07:01 AM
savagefan's Avatar
savagefan
He mentioned a no-spark condition so diesel engine is out. Many refer to crank position sensor as ckp on gassers. Ford calls it VRS variable reluctance sensor on EDIS6 systems. On a 4.0 it's diametrically opposed from #8 in the diagram.
Old Feb 15, 2006 | 07:06 AM
subford's Avatar
subford
Sorry for the edit, I did not think anybody would come back that fast.
What is a "jiggy"?
Old Feb 15, 2006 | 07:15 AM
indyjim's Avatar
indyjim
93 ranger 2wd 4.0 it is the crank sensor,the thing about it is when it does fireup you can just touch the sensor very lightley and it will shut down..
Old Feb 15, 2006 | 07:21 AM
indyjim's Avatar
indyjim
and it has a new coilpack-icm-pcm(comp) and the list goes on,thanks for your help so far.
Old Feb 15, 2006 | 07:56 AM
subford's Avatar
subford
I would say you have one of the three things listed below.
1. Bad Plug or Wire.
2. Bad CKP Sensor
3. Ckp sensor to far away from ring.
Old Feb 15, 2006 | 12:14 PM
Franklin2's Avatar
Franklin2
Well, you are right on top of it, and pretty much have it narrowed down. It's going to be one of the problems subford mentioned. You need to get a good light, and being very watchful, take the plug off the sensor and inspect everything you can to see if you can spot the problem. You never know, the problem might be the connections on the sensor itself.
Or, if you could buy that part of the harness, and a new sensor, that would probably fix it without worrying about what the real problem was.
Old Feb 16, 2006 | 05:55 PM
indyjim's Avatar
indyjim
just want to let you know that it was the ckp sensor,and want to thankall of you for your help with this,just wish i would have found this fourm sooner,so anyhow thanks again....
whh333
Dec 17, 2014 06:04 AM
raptor2005
Jan 20, 2013 03:30 PM
copuntryboy
1997 - 2003 F150
Apr 20, 2012 10:32 PM
grinekb
Jan 19, 2009 02:56 PM
