Towing capacity of Ford E series van?
I'm looking into get an E-series Ford van from '87 and was curious as to what is the towing capacity of the van. I haven't been able to find this anywhere online, except that 2006 models can tow from 6.2k to 10k pounds. Any rough estimates would be fine.
Thanks in advance.
Thanks in advance.
I do know it's an E-150 but I'm not sure of the tranny or engine. Do you happen to know what the E-150 can pull with the worst engine/tranny?
Why do you say I there's only so much I'd want to pull with a 302?
I'm looking to use it for pulling a trailer with a car.
2k-3k.
At the min. you would want a 351w and the best option would be a 460. Towing the 460 probably would get much better gas mileage then the 351w anyway.
2k-3k.
Me, my '87 E150 302 initially could barely haul itself up hills. The condition of the vehicle makes quite a difference in the actual towing capability. New timing chain, sensors, plugs, fixed vac leaks, etc and it hauls around 1000 lbs of trailer weight pretty well on the highway, I'd be happy hauling that weight state-to-state and hitting on-ramps. Dunno about double or triple that weight.
2k-3k.
2k-3k.
Horsepower wise the 300 six is a gutless turd, so it's not going to win any stoplight confrontations, but inline engines are very good at making torque, so it should do a decent job of towing the weight....as long as you're not in any hurry to get there.
If it's in good running condition it will get better economy than any of the gas V-8's.
The van body and a loaded car trailer will put a lot of stress on the half ton drive train, you might consider an E-250 or 350 with a diesel.
