Need help with altnater
Old Feb 14, 2006 | 06:15 PM
earnies2's Avatar
earnies2
Talking Need help with altnater
Alt starts discharging at 1800 RPM - brand new alternator. Old did the same. Belt is good, tensioner is good, idler pulley is good, belt is tight. Batteries are new. Brand new positive cable, grounds are good. At 1800 RPM regardless of load battery light comes on, lights dim, and volts drop to 12.1 on a volt meter. Please help
Old Feb 14, 2006 | 06:24 PM
1997F-350's Avatar
1997F-350
same thing was happening to me. but since you got a new one well maybe its still messed up take it back and try another.....if that doesnt work well hopefully the electrical gods will see this post. i such at electrical things. good luck
Old Feb 14, 2006 | 06:39 PM
DaBigTow's Avatar
DaBigTow
Take a look at the wiring at the alternator. I had the heater hose knock the white/black wire loose on the single-pin connector; same response.
Old Apr 3, 2006 | 08:01 AM
bockusd's Avatar
bockusd
When does the alternator supposed to kick in
On the subject of Alternators:
After the engine starts it can take up to 1 Min. before the alternator starts charging, regardless of engine speed. Is this normal? If so Why? This the 2nd alternator I put in, both seem to have the same behaviour.
thanks
db
Old Apr 3, 2006 | 08:15 AM
jimkidd's Avatar
jimkidd
thanks
db
Yeap.
jimbo
Old Apr 3, 2006 | 10:12 AM
1997F-350's Avatar
1997F-350
thanks
db
it starts showing higher voltage once the gpr relay de activates.
Old Apr 3, 2006 | 10:24 AM
tjbeggs's Avatar
tjbeggs
the alternator doesn't charge for approxaimately 40 seconds after start up its controlled by the computer and it actually has nothing to do with glow plugs. the glow plug are on for various times depending on engine and air temps (anyhwhere from 0to 120 seconds)but the alt never charges until 40 seconds. not shorter not longer. so yes it is normal.
Fordteamone
Electrical Systems/Wiring
Dec 11, 2010 07:47 PM
Montana F-350
Dec 11, 2009 10:17 PM
61 uni
Oct 17, 2009 10:07 PM
leerw2
1997 - 2003 F150
Mar 15, 2009 11:33 AM
bronco351
1978 - 1996 Big Bronco
Jun 2, 2003 11:42 PM
