351M casting number
Old Feb 14, 2006 | 01:52 PM
acefig21's Avatar
acefig21
351M casting number
Where is the casting number or engine ID number located on a 351M from a 77 F100......Thanks
Old Feb 14, 2006 | 02:44 PM
Mil1ion's Avatar
Mil1ion
It doesn't matter because the engine was designed for a full size Ford car.
The 400 will also have the same casting numbers.
The 3rd digit will be an A and the 4th will be an E .
What is it you are trying to figure out ?
The best info is on a buck tag usually located under a mounting bolt for the coil.
Btw, this is an engine question and would be best posted in the 335 engine series forum.
Old Feb 14, 2006 | 02:50 PM
acefig21's Avatar
acefig21
i'm trying to order a new long block assembly and i keep getting asked which engine is it. There seems to be four for that year model
Old Feb 14, 2006 | 02:51 PM
Mil1ion's Avatar
Mil1ion
Why not just order a 1971 400 instead ?
https://www.ford-trucks.com/article/...00_Engine.html
The only way to tell the difference is to measure the stroke.
Old Feb 14, 2006 | 02:57 PM
Torque1st's Avatar
Torque1st
Posting Legend
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have on FTE. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
Old Feb 14, 2006 | 04:13 PM
acefig21's Avatar
acefig21
What are the advantages of the 400 over the 351 and will i have to make changes or will it slip right in
Old Feb 14, 2006 | 07:29 PM
grclark351's Avatar
grclark351
no changes at all. the only difference between the 351M and the 400 is the crank and the pistons, all internal. externally the engines are identical. if you need to have the proper emissions equipment for a visual inspection you should order for the year of the truck, otherwise the 71 400 should have more compression and none of the smog passages in the heads. or you could order a 71 400 short block and put the correct year smog heads on it yourself, it'll be better than a smogger long block. that is IF the rebuilder does use the flat top pistons(instead of dished) for a 71?
nastar44
1966 - 1977 Early Broncos
Jun 3, 2011 08:51 AM
rooster41
New Member Introductions
Aug 26, 2009 03:01 PM
Fat Diesel
Apr 21, 2009 08:22 PM
jacob_9249
Jul 26, 2008 08:04 AM
kmart4
Nov 20, 2005 10:43 AM
