460 changes
Old Feb 13, 2006 | 10:25 PM
theguy_88's Avatar
theguy_88
Question 460 changes
did ford change their 460 blocks from 77 to 91. would the trans mission from the 77 fit on the 91? also from switching the fuel injection to a carb would the manifold fit?
Old Feb 14, 2006 | 12:39 AM
monsterbaby's Avatar
monsterbaby
hte blocks changed in 79, and you can't put the earlier cranks in the 79 or later blocks and the later blocks have longer cyl walls so work good for stroker motors. Also in 79 the switched to external balance so you can't swap flywheels with the earlier ones. But the physical external dimensions stayed teh same so yes the bellhousing will bolt up as well as the accesories such as PS, and alt.
The intakes between FI, and carbed will not cross the heads are different but you can bolt the carbed heads onto the FI short block or viceversa if you want to do that swap.
peeples93
1978 - 1996 Big Bronco
Sep 13, 2015 09:46 AM
Lynch97
Mar 30, 2015 06:34 PM
adworden
Jan 19, 2015 10:54 PM
Ordnance
Feb 12, 2014 08:25 AM
