460 changes
Old 02-13-2006, 10:25 PM
theguy_88's Avatar
theguy_88
theguy_88 is offline
Question 460 changes
did ford change their 460 blocks from 77 to 91. would the trans mission from the 77 fit on the 91? also from switching the fuel injection to a carb would the manifold fit?
Old 02-14-2006, 12:39 AM
monsterbaby's Avatar
monsterbaby
monsterbaby is offline
hte blocks changed in 79, and you can't put the earlier cranks in the 79 or later blocks and the later blocks have longer cyl walls so work good for stroker motors. Also in 79 the switched to external balance so you can't swap flywheels with the earlier ones. But the physical external dimensions stayed teh same so yes the bellhousing will bolt up as well as the accesories such as PS, and alt.
The intakes between FI, and carbed will not cross the heads are different but you can bolt the carbed heads onto the FI short block or viceversa if you want to do that swap.
peeples93
1978 - 1996 Big Bronco
09-13-2015 09:46 AM
Lynch97
03-30-2015 06:34 PM
adworden
01-19-2015 10:54 PM
Ordnance
02-12-2014 08:25 AM
Quick Reply: 460 changes
