Code P0316 Ranger 2003
Old Feb 13, 2006 | 09:09 PM
rangerin40's Avatar
rangerin40
Great site! I am getting the P0316 code on my 2003 2.3L. I read a posting from a person with a similar issue. I am not as well versed in auto repair as most people on this site, so the answer was a little Greek to me. Could someone please walk me through what I should check next. I did disconnected my battery and changed my plugs last weekend and am still getting the check engine light after about 100 miles of driving. I will say that I did check the Ohms on the plug wires and they did fall in the correct range. I will fore warn you that I noticed the check engine light as I started to hear the engine ping when the rpms were at about 2000. I didn't hear it before or after 2000 rpms. I changed my airfilter thinking it would eliminate the check engine light. It didn't, but the ping went away and the filter was absolutely filthy. I hope I didn't jump around too much. I would appreciate any help you can give.
Thank you.
Old Feb 13, 2006 | 09:33 PM
pike_hunter's Avatar
pike_hunter
Go to the technical information at the beginning of the forum and look for the link on how to clean the MAF. It helped some on the problems that I had. May help on yours. A good place to start.
Also go to autozone or advance auto parts in your area and ask them to pull the codes and then post them here. There a lot of very knowledgeable people here that can help with diagnosing the problem.
Old Feb 13, 2006 | 09:53 PM
rangerin40's Avatar
rangerin40
Thanks Pike Hunter. Autozone was were I found my code and that was the only code that was present. I will clean my MAF and see if it helps. Thank you.
Old Feb 13, 2006 | 10:09 PM
pike_hunter
The only reference that I can find for a P0316 is for a misfire in the first 1000 revolutions. There is a technical bulletin about this using reformulated gas when over 50 degrees, but this is for a 3.0 L and not the 2.3 L. Good luck, over my capabilities.
Old Feb 16, 2006 | 09:09 PM
rangerin40's Avatar
rangerin40
I cleaned my MAF and after about 50 miles the check engine light came back on. The truck does seem to run a little smoother, but when starting the truck it still idles down rough. When I drive it for even 50 feet it will settle down. If anyone has any ither suggestions I am listening,
Thank you.
oldhokie
Escape & Escape Hybrid
Apr 1, 2022 11:34 AM
roodyl
29
Jul 17, 2017 09:16 AM
jpeloian
23
Oct 31, 2011 09:49 AM
eXcap3
Oct 22, 2011 01:27 PM
88 Bronco
21
Dec 22, 2009 11:46 AM
