4x4 problems
Old Feb 13, 2006 | 08:34 PM
jimbos250's Avatar
jimbos250
Unhappy 4x4 problems
i have an 03 fx4 and sometimes the 4x4 doesnt work and if i take out the fuse #19 its back to normal .its seems like a electrical problem or something need help please.
Old Feb 14, 2006 | 08:49 AM
Maxium4x4's Avatar
Maxium4x4
The gearmotor encoder assembly is mounted externally on the transfer case. It drives a rotary cam which moves the mode fork and the range fork within the transfer case between the 4X4, 4X4 LOW, and 2WD range positions.
  • Central junction box (CJB) fuse 59 (30A)
  • Central junction box (CJB) fuse 27 (15A), 34 (10A)
  • 4WD control module
  • Pulse vacuum hublock (PVH) solenoid
  • Wiring harness
  • Mode select switch (MSS)
  • Gearmotor encoder assembly
  • Connector(s)
  • Shift relays
  • Circuitry
19 10A* Body security module/4x4 module
Old Feb 18, 2006 | 12:03 PM
jimbos250's Avatar
jimbos250
what does that mean if i take the fuse #19 out is like reseting the security module .what causes that and most important how do i fix it . does that security module have something to do with an alarm.
Old Feb 18, 2006 | 04:21 PM
Maxium4x4's Avatar
Maxium4x4
19 powers the security module and your 4x4 module. I would check your module at the trans case for corrosion at the connection first then go from that.
When you pulled the 19 fuse you eliminated the power source for the module.
a ayala
May 24, 2011 10:28 AM
sro2000x
Feb 16, 2010 12:31 AM
jimbos250
Feb 13, 2006 07:54 PM
WildcatDE75
1983 - 2012 Ranger & B-Series
Mar 9, 2004 07:36 AM
