Why won't it start?
Old May 20, 2001 | 11:42 PM
ogre316's Avatar
ogre316
Why won't it start?
I have put a new starter, a new solenoid switch, a new battery, and 2 new battery cables on my 76 F-100 but it still won't even turn the lights on. I took the electric brakes that some moron put on there wrong off because I suspected that they were killing my battery but the truck still shows no signs of life. What's wrong? Any help would be appreciated greatly.
Old May 21, 2001 | 11:48 AM
oddballfords's Avatar
oddballfords
Why won't it start?
Check all of your fuses. then get a wiring diagram and check everything for shorts and you also might want to check out your switch some times they get wore to where things short out there.
Old May 21, 2001 | 12:20 PM
lastchance's Avatar
lastchance
Why won't it start?
You might want to check the fusible links located at the battery side of the starter selenoid. If they are still the original ones they will have a small rubber tag on them that says fusible link on them. Take a test light, ground the one end, then hold it on the battery side of your selenoid. It should light. Now, unravel the tape (if the wiring is covered) at the selenoid and check the fusible link wires. I usually pierce the wire just past the splice to see if it has power in the fusible link or not. From reading all that you have already done I am guessing this is your problem. I am also assuming that you mean you are getting no electrical power whatsoever to anything in the truck.
Another thing to try if you have power through the fusible links: Turn your lights or anything in the truck on (also assuming your battery is charged) and take your test light from the negative side of the battery to a grounding point on the BODY. If the light lights, you do not have a sufficient ground to the body from the negative side of the battery (body ground). Make sure somewhere along the line you have a good cable going from the engine to the frame or body. The smaller 10 GA wire on the new battery cables I usually run to a fender or battery box bolt to make sure it is supplying a good ground to the body.
Old May 24, 2001 | 09:25 PM
hunter_firefighter's Avatar
hunter_firefighter
Why won't it start?
I had the exact same problem with my 79 f-150 turned out the ignition switch was bad 3 days and 150 dollars later it took 10 minutes and 10 dollars to fix but a lesson learned. good luck
1979 F-150 Custom 4x4 Shortbox
Old May 24, 2001 | 09:42 PM
Ford79's Avatar
Ford79
Why won't it start?
rmacinc22
28
Nov 18, 2014 07:38 AM
Fosterch
Modular V8 (4.6L, 5.4L)
Nov 16, 2014 07:22 PM
truckbeast
Nov 7, 2012 08:12 AM
dbf74
Apr 3, 2012 09:48 PM
kimf350
Nov 22, 2004 06:16 PM
