Overhead Console 98-01
Old Feb 13, 2006 | 06:02 PM
TexasGuy001's Avatar
TexasGuy001
Question Overhead Console 98-01
I was hoping someone could tell give me some info on the 98 or 99 Mountaineer overhead console I just acquired. From what I understand they are the same from 98-01. I am going to install it in my truck. I will be splicing these connections and running my own wire, since my truck does not have the wiring harness for this. What I need to know is the wiring. Can someone tell what the color of the wires are for the different functions of the console. I need to know at least the color for ground, switched power, constant power, thermometer sensor. Any input is appreciated.
Old Mar 22, 2006 | 11:45 PM
TexasGuy001
Doesn't anybody know what the connector pinouts are on this. All of my consoles wires are black and one is white.
Old Mar 23, 2006 | 08:47 AM
ledbetter's Avatar
ledbetter
Did this with an 01 Explorer once. What year is your Mountaineer? I think there are supposed to be eight wires on the console according to another forum:
Red/Blue = Dimmer
Blue/Yellow&Blue/White = Temp sensor
Black = Ground
Black/Blue&Green/Orange = Dome Light
Gray/Black = Vehicle sensor
Yellow/Gray = Main power
I know there's a sticky in the Ranger forum about installing a Explorer console into a Ranger. They might have more info there. Or if you do google or yahoo, I htink you'll find a few installation tips out there...
Old Mar 23, 2006 | 09:16 AM
TexasGuy001
The Mountaineer is a 98. All of the wires are black except one is white. This is at the connector coming off of the console. There are 8 wires.
Old Mar 23, 2006 | 10:28 AM
ledbetter's Avatar
ledbetter
You might head to the junkyard and get the wiring harness that has the color-coded wires the connector would hook up to...
Just found a diagram for a 96 Explorer, but I think the consoles should be similar. Just make sure the connectors are the same:
http://www.supermotors.org/vehicles/...358&original=1
Old Mar 23, 2006 | 07:56 PM
TexasGuy001
Thats exactly what I was looking for. These consoles are the same as that 96. I think the only difference is the display lights up in green on mine and blueish color on the older ones. They look identicle. Thanks again.
Frozen_Joker
1983 - 2012 Ranger & B-Series
Dec 3, 2013 09:14 PM
90pioneer
Feb 26, 2013 08:53 AM
norfolknova
30
Aug 9, 2012 03:20 PM
thewizard
Jun 12, 2005 08:58 PM
truckalpers
1997 - 2003 F150
Feb 3, 2005 01:14 PM
