I have a brand new battery that is frozen or particially frozen. I havn't looked in all the cells but the first one was solid and the 2nd and 3rd were semi-frozen. At one point the battery was low and I made the mistake of putting well water (tap) in it instead of distilled. I duno if that makes much of a difference but I'm wondering if there is anything in particular I should do...
My plan is to bring the battery inside and let it thaw out and attempt to charge it and see if I can get it to work...
Yeah but I've heard that tap water isn't good to put in there...
It would freeze either way on a dead battery...
That is true, because of the minerals in the water. It really depends on where you live and the quality of water you have. But to be safe, distilled water is the best. But the tap water didn't cause it to freeze.
As long as the water doesn't crack the lead plates inside, or the plastic housing on the outside, you're probably okay once it thaws out. Most battery damage from freezing is due to water expanding as it becomes ice, breaking the lead plates off the mounts so you have less "cells" so to speak.
Just be careful where you place it indoors - just in case there is a hairline fracture in the case - you don't want to ruin your carpeting or hardwoods. If you have an old cookie pan (large pan with about a 1/2" high lip around the perimeter) you could place the battery on that to protect whatever you rest the battery on.
The case isn't split, no bulging either. No signs of leakage. I'll try to see if I can tell whether or not the plates are damaged, but it's hard to see inside and check.
If one is damaged and I don't see it or arn't able to tell, can I still charge it anyway and I'll find out that the plates are bad if it doesn't take/hold a charge? Or is this a little too dangerous (don't need any explosions)?
After you charge it, measure the voltage without the charger hooked up. If you have 13-something volts none of the plates are broken off their mounts.
If you get nothing, or less than 13, then something inside broke due to the expanding ice.
Like TJTransport said, it doesn't hurt anything to charge the battery if a plate is broken. Chargers are current limited. Just don't put the charger on the "start" setting
Well I put my automatic charger on it. It's a small snowmobile battery. It was going at about 5-6 amps at first, not sure what the pattern was on the way down but when I went to check on it I found that it had stopped charging, charger said it was done, and some of the water/acid is leaking out of some of the caps. I screwed them down but they're still leaking. I don't have any baking soda in the house, how else can I neutralize the acid? It's not leaking down the battery to the floor, but if it keeps going it will (doesn't look likely). It's mainly just sitting around the top, but I put a piece of wood down and it's on a concrete floor. How should I handle this? It was putting out 12.18v.
The water is probably coming from the battery being overfilled a little bit. If it's fully charged, the leaking is probably over. I would wipe it off with a rag you didn't care about, and then try it.
It's now showing about 11.80 volts. I wonder if I should put a light or other load on it and then recharge it....cycle it....?
If it's fully charged and you only have 11.xx volts, I'd skip it and just replace the battery. Even if it works for a while, the last thing you need is to have to go somewhere important, be a few hundred miles away from home, and have a dead battery.
