Is there such a thing as a way to calibrate or test the accuracy of a torque wrench? I am asking of course because I snapped a bolt off with my torque wrench set at 40 ft/lbs. last night. I had often wondered if the wrenches were accurate, but had never worried about it. This particular wrench is one that you set and it clicks when the desired torque has been achieved. The bolt I broke was actually one of the last bolts I tightened down, and the wrench seemed to work fine on the previous bolts.
Yes, there is a way to have wrenches calibrated. First, though, and I don't mean to sound like a jerk... Is it a decent tool, worth calibrating? If it's a $10 wrench you're going to get the accuracy of a $10 wrench. If it's a high quality piece that may have got out of wack for a number of reasons, take it to your dealer or tool store and they should be able to help you out. I learned the importance of accuracy when I was a transmission tech. Tighten a valve body down innacurately and you CAN have problems you never dreamed of! Hope this helps. Good luck.
Maybe it was not the wrench. What kind of bolt was it? I have seen bolts made to a low grade snap when taking them OFF let alone tightening them to low torque spec. If it was a perviously used bolt, it could have streched on install and upon re-install, broke off. I see this a lot with low grade stuff right at the shoulder. Just a thought.
This was a used bolt that I was re-installing on the rear diff cover so I guess this could be a possibility. I paid a pretty fair price for the wrench so I will take it in to the auto parts store and see about having it checked out. Thanks for the quick responses.
Sure hope so other wise the Ford spec book I was using was wrong. I will check it today and make sure. I sure hope I don't have donkey ears scraping the ceiling about this.
[updated:LAST EDITED ON 16-Mar-02 AT 11:50 AM (EST)] If this is a bolt that holds the gasketed differential cover on, there is no way that 30-40 ft/lbs of torque are correct. The sheet metal of the cover would be so distorted at the bolt holes that it would more than likely end up leaking. If you look at the head of the bolt, and it has a raised edge all the way around, with no markings, it is a 'pan gasket bolt' that will break with the torque you applied. For it to handle that kind of torque, it would have markings on the head- dashes pointing radially as an example. The lowest grade of bolt has no markings..and a raised edge around the head or a depressed center if you want to look at it that way.
40" lb is about 4 ft lb, which makes sense for a sheet metal cover.
tom
Tom, it's not 40 inch-lbs, unless you want a leaky rear housing. That's a hair over 3 foot-lbs. Even oil pan bolts get tightened more than that.
The specs for the Dana 44, 60 and 70 diff cover bolts are 30 FOOT-pounds. Most others are around the same. The stamped steel covers on most diffs are much thicker than just sheet metal.
A simple way to check your wrench is to stick an old socket on it and clamp the socket in a vice so that the wrench is free to rotate. Rotate the handle to a horizontal position. Hang a known weight on it using a loop of wire. Measure the distance between where you hang the wire and the pivot point of the wrench head, and divide by 12. Then multiply this by your weight.
For example, if you hang a 30lb weight at 10 inches, your applied torque is 3010/12)=25ft-lbs. If you have a click-type wrench, you would adjust the setting and see if it clicks when it's set near 25 ft-lbs.
If you can't find a good weight, use a bucket & fill it using 1 gallon water bottles... every gallon you add weighs 8.3 lbs.
Your best bet is to find a local calibration lab that does torque wrenches. To check a single point on any wrench is a fine quick check, but does not cover the range of the wrench. The water method is a so-so functional test, but doesn't take into consideration the weight of the handle, container, or what you use to hang it with, which can a factor on a long or heavy wrench! The angle the wrench deflects from horizontal when you hang the weight will also affect your test! Repeatabilty is something that needs to be checked as well.
If your wrench has been dropped, even once, (and all have been if they are used at all), that can change the calibration too.
To sum it all up, I again suggest finding a local lab and having your wrenches cal'd by them. This includes dial, break type, or deflection beam. Cost should be nominal, and will save you lots of grief down the road!
To ease your mind, I have been calibrating tools for 20+ years.
[updated:LAST EDITED ON 05-Jun-02 AT 04:26 PM (EST)]So Rikfish
When are you starting your bussiness ,we will all send you our
wrench's!!!!!
Rich
Ford Trucks Built Tough!
not with rocks
Watch out "X" Mayor of Truckville
[updated:LAST EDITED ON 05-Jun-02 AT 05:45 PM (EST)]Rich,
Hmmmm, not a bad idea... Shipping would probably be more than the cost of calibration! That, and too many labs with torque capability around here.
One quick suggestion for all users. After you are done using your adjustable breakover type wrench, set it to the lowest setting. The springs tend to develop a memory.
Primary rig is:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Sunroof, and some 32" BFG Muds .
Pictures are in!!
Then theres:
99' Mustang GT 4.6L
88' F-250 Superduty 4x4 351/c6
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 with a
3 spd column shifter. Top speed is 65mph, Go Baby Go!
