ignition timing & vacuum
Old Feb 13, 2006 | 07:49 AM
cwpowell's Avatar
cwpowell
can anyone give me the degrees to set the timing on a 78 302 engine, and also how much vacuum should my gauge be showing? Thanks for your help, Charlie
Old Feb 13, 2006 | 11:39 AM
Larry_the_handyman's Avatar
Larry_the_handyman
Disconnect the vacuum advance from the distributor. Set the timing to 8 degrees Before Top Dead Center. Then reconnect the vacuum line. You should get somewhere between 5 and 20 inches of Hg depending on engine speed.
