need some info 250 hd
Old Feb 13, 2006 | 02:23 AM
jariet's Avatar
jariet
Exclamation need some info 250 hd
hi i have f 250 hd -88 4x4 213hp inject engine , real is 10,25 sterling but i dont know what i have in front, and i need some info on engine
Old Feb 14, 2006 | 07:18 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Feb 14, 2006 | 09:07 AM
tjc transport's Avatar
tjc transport
i ain't rite
a F250 hd should have a dana 50 ttb front axle in it. engine id will be on a tag on the valve cover, or hood. either a 4.9 inline 6, or 5.0, 5.8, 7.5 V8 gas, or 7.3 diesel.
Old Feb 16, 2006 | 08:44 AM
jroehl's Avatar
jroehl
If it's 213hp, then you more than likely have the 460 (7.5L) gas V-8. Even in '93, the 302 and 351 v-8s were only at 185 and 200hp, respectively.
Though I'm curious as to how/why someone would know that an engine is 213hp and not know what it physically is.
Jason
Old Feb 16, 2006 | 11:37 AM
jariet's Avatar
jariet
hi i have f 250 hd -88 4x4 213hp inject engine , real is 10,25 sterling but i dont know what i have in front, and i need some info on engine.
The VIN is 1FTHF26H5JNB58o42 , and TRANS Z , AXEL 39 , SPRING 6F
H= 351 EFI 213HP ?
Old Feb 16, 2006 | 11:38 AM
andym's Avatar
andym
That's a good question. Also, the 8th letter of the VIN will tell what motor is in it.
G=460 H=351 N=302 (but it won't be in a heavy duty) and Y=300. I forget the diesel, but you'd know it if you had one.
The front could either be a D44HD or a D50. If it is an extended cab or has the snowfighter package, it has a 50. Otherwise, it's a 44.
Old Feb 16, 2006 | 11:46 AM
jariet's Avatar
jariet
Smile
H= 351 EFI 213HP ?
THANKS AGAIN
Old Feb 25, 2006 | 10:07 AM
Ford_for_Brains's Avatar
Ford_for_Brains
H=351-200hp, is this thing parked in sand? (had to ask, sounds alot like the ones in chatrooms for overseas)
Old Feb 26, 2006 | 12:15 AM
F350JOHN's Avatar
F350JOHN
If its eight lugs, its most likely a Dana 50 TTB. If its five lug its most likely a Dana 44 TTB, But sence you said you have a 10.25 rear its almost for sure a Dana 50 TTB
Old Feb 26, 2006 | 10:48 AM
u2slow's Avatar
u2slow
Nothing is for sure.... my buddy has a '90 F250 with the 10.25 full-floater, but just the D44ttb up front.
I think the front axle has more to do with the GVWR than anything.
Old Feb 26, 2006 | 11:50 AM
tjc transport
i ain't rite
in 88 you could get a 250 with a light front diff, and a 250 HD with a D50.
