Sylenoid Body question...
Old Feb 12, 2006 | 09:54 PM
handyman43358's Avatar
handyman43358
95 F-150 E4OD tranny. Like I stated in my earlier posts, the tranny seems to be in 1st no matter what. It fights itself in reverse and park, it moves forward and stays in first even while its in nuetral. Sound like the sylenoid body is failing, or something else? Is it possible that the plug on the passenger side could have gotten wet a while back and has malfunctioned since?
One more question... Is it possible to pull out the valve body and sylenoid body while it's still in the truck, or do I need to pull the tranny before doing so?
Old Feb 12, 2006 | 10:32 PM
quicklook2's Avatar
quicklook2
hey, handyman, yes the manual says to check corrosian at connector.
and you can remove just the valve body and solenoid body.
did you check cd manual for pics?
Old Feb 13, 2006 | 04:27 PM
handyman43358
hey quicklook, I figured it wouldn't have been a problem taking them out. First step once I get it in the garage will be to look at that connector... because even before this, the transmission was very moody. Some days it would work fine, others it wouldn't want to move.
I read up on the CD manual you sent me and got a good look at what I'm going to get into. Doesn't seem to be too bad, thanks again for that CD! It's been a lifesaver.
