oil pressure ?
Old Feb 13, 2006 | 04:25 PM
earl964's Avatar
earl964
Exclamation oil pressure ?
Does anyone know how I can check my oil pressure gage I have an 88 F250 351 motor . The needle on the gage only moves a little when it is running and when you come to a stop the needle goes back to the left and the red engine light comes on the oil level is fine . Any help would be great .
Old Feb 13, 2006 | 04:41 PM
Kemicalburns's Avatar
Kemicalburns
replace with a mechanical oil pressure gauge. the stock ford gauge is not a true gauge and frankly sucks. this way you will truely know what the pressure is. the wire going to the sending unit which is by the oil filter can be grounded to keep the check engine light off or you can put a t fitting in that area and run both the solenoid and the mechanical gauge line.
