water pump
Old Feb 12, 2006 | 05:22 PM
screwloose2's Avatar
screwloose2
water pump
does anyone know if a 1968 ford 302 water pump , inlet pass side can be used on a 76-79 302 ?
thanks jeff
Old Feb 12, 2006 | 06:29 PM
Larry_the_handyman's Avatar
Larry_the_handyman
Autozone lists two different part numbers for the two engines.
Old Feb 12, 2006 | 07:26 PM
nixer's Avatar
nixer
look up timing covers that would tell you if they would be interchangable.
if your moving the outlet the part numbers for the pump would be different.
