Steering Box Location
Old Feb 12, 2006 | 06:16 AM
g84t8f1's Avatar
g84t8f1
Question Steering Box Location
Ok.I installed a kit to put a gm power steering box on my 48.
It is mounted 1" closer to the firewall than they say to mount it.I put it there because of my motor mounts.It is good where it is because the steering column is inline with the box.If I move it the 1" would need a universal joint.Where I put it I had to trim the cab mount bracket and 1 bolt is thur the spring mount bracket.I think they set it forward !" so you don't have to do the triming.Ok I'm getting ready to box my frame so if I need to move the box I can.It would be easy to do.I'd like to keep it where it is if it will drive alright.What do you think?
ART
Old Feb 12, 2006 | 06:48 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Art,
You are probably right about the reason the box is supposed to go one inch further forward. It would not be as good a kit if it required trimming the cab mount bracket and caused interference with the spring mount bracket. The only reservation I would have is the steering linkage. Have you connected the linkage to see it it works okay. Do the wheels turn the same amount in either direction and does everything line up or will you have to modify parts of the linkage also to make it work.
Vern
Old Feb 12, 2006 | 12:57 PM
AXracer's Avatar
AXracer
The steering box location is critical in reducing bump steer. I'm not familiar with the conversion you did, but the link end of the pitman arm should be in line with the rear spring eye and at a similar height.
Old Feb 12, 2006 | 08:38 PM
g84t8f1's Avatar
g84t8f1
Thanks.I moved it foward. The directions I got the frist time was hand writen and wrong. I got the folks to email me a set of the right ones.Ended up moving the box 3" foward.I think it should help make it drive better.
ART
