Transmission change
Old Feb 12, 2006 | 01:03 PM
ncranchero's Avatar
ncranchero
Transmission change
Anyone know what effect it will have on the ECM computer if I change from the 4R70W to a non-electric AOD in a 95 F150/5.0L ? Anyone done this?
Old Feb 12, 2006 | 02:52 PM
MustangGT221's Avatar
MustangGT221
The computer will wonder where the tranny is.
You'll need to switch to another computer that doesn't have an electronically controlled transmission. I'm also 95% sure you have a MAF EFI system instead of the more common speed density system. So you'd need a MAF computer as well.
A computer from a 87ish-93 mustang will work, they are usually A9L or A9P computers. It should swap right in but you may want to get a pin diagram from fordfuelinjection.com and make sure there arn't any wires in the wiring harness that need to be changed. You may or may not need to re-wire the o2 sensor.
Old Feb 12, 2006 | 02:55 PM
ncranchero's Avatar
ncranchero
I have a '93 T-bird I'm swapping the engine from. That ECM will do won't it?
run6.0run
Nov 5, 2013 05:52 PM
jgust001
Oct 27, 2012 11:24 AM
genbryan
Jan 3, 2010 01:57 AM
idealtrucks
Nov 29, 2006 10:45 PM
grey77
2004 - 2008 F150
Aug 3, 2004 06:33 PM
