Replacing the clutch
Old Feb 11, 2006 | 09:45 AM
jonm61's Avatar
jonm61
It looks like I'm going to be replacing the clutch on my '99 4.0 OHV Explorer. I'm looking for any input or advice from those who have done this before. I haven't decided if I'm going to do it my self or take it to a shop, but I'm leaning towards doing it myself.
Any thoughts/tips/suggestions?
Thanks!
Old Feb 11, 2006 | 10:08 AM
amish77's Avatar
amish77
well The only one I've replaced wasn't hydraulic, but here's what I learned in the process.
1.) while a jack with a big foot will get the transmission in and out, a true transmission jack will save you at least one migrane, either on the pulling out or the putting in.
2.) get yourself some engine degreaser, and some brake cleaner. not exactly what you'd think of right off. it helps to clean up the tranny and around the bellhousing before you pull the transmission so you don't get a bunch of crap around the clutch when you go to put it in. Make sure to clean off the clutch really good before you bolt the tranny back on.
3.) the kits are pretty complete just about anywhere you get them. You should get the pressure plate, throwout bearing, and alignment tool along with the clutch. This makes the job a lot easier, as you don't have to run around finding all the parts seperate.
4.) Make sure to mark your shifter linkage locations B4 you remove the tranny. I messed this up and it took me quite a few hours to get the linkage back together.
5.) if you tip the tranny back too far it will leak fluid, so try not to as life can get a little messy.
other than that it makes for a pretty straightforward job, oh and a buddy goes a long way on this one. He can sight for you when you go to put the tranny back on. getting the tranmission to line up is probably the hardest part of the job.
IDI-Charlie
Sep 3, 2016 11:32 PM
banks0531
Jul 10, 2016 02:07 PM
dmueller71
Sep 18, 2015 11:21 PM
TBoxx
Jun 12, 2015 05:08 PM
WALT G
Jul 13, 2009 03:11 PM
