APC Projector Headlights
Old Feb 10, 2006 | 08:35 PM
sirata's Avatar
sirata
Anyone install APC projector Headlights? They have a little switch to dash mount for the driving lights. Was wondering if anyone has wired them to the ignition so they will shut down with the key off. I can see leaving them on and draining the battery.
Thx,
Dana
soupclub@verizon.net
Old Feb 10, 2006 | 09:40 PM
FTE Herman's Avatar
FTE Herman
Hi Dana. If you are able to remove the kick panel on your driver's side, you'll find a bundle of wires. One of these will be switched.
*HOWEVER*
DO NOT wire your lights into this lead. It will cause too much current to be drawn on this circuit. INSTEAD use this lead to energize your switch to a RELAY. The relay connects the current from the BATTERY (fused of course) to you lights.
Hope this helps.
SCRWDRVR
2004 - 2008 F150
Mar 23, 2016 08:06 PM
pdqracer
Ford Truck Parts for Sale
Nov 21, 2015 07:52 AM
jbravata2
16
Aug 21, 2015 07:15 PM
LuisG818
Nov 19, 2014 02:56 AM
