Propane
Old Feb 10, 2006 | 07:19 PM
bassproguy07's Avatar
bassproguy07
Propane
Ok i was lookin on the Bullydog website, and i came across one of their propane injecton kits. It says it is grat for the engine and works great on any turbocharged engine, but would it work on a non turbo diesel?? Also what are some of the precautions needed when using it, can it damage the engine?
Old Feb 10, 2006 | 10:01 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
From what I've read, adding a little propane will improve the power output and fuel economy of any diesel engine. I think most of the systems available now are recommended for turbo diesels because they use hobbs switches (boost activated) to turn them on.
Thread moved to proper forum.
Old Feb 10, 2006 | 11:32 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Adding propane on a natural aspirated motor will give you a small power gain.
But this is adding more fuel when you really need more air to burn the fuel.
Makes a big difference with a turbo motor.
I think the power shot is to expensive for the amount of gain you would get on a non turbo motor.
Old Feb 11, 2006 | 01:15 AM
Phydeaux88's Avatar
Phydeaux88
That's your opinion but not mine. I get from 73 to 78 RWHP out of my powershot 2000. Well worth the $650 price tag, and if you order from Tymar you can get it cheaper.
Cookie is right Powershot and for that matter most other propane systems use boost to control the flow of propane. There are some folks here that have home made systems but with out the ability to increase/decrease flow as needed it would be a less than effective system
Old Feb 25, 2006 | 02:30 PM
James A. Simpson's Avatar
James A. Simpson
Thumbs up Propane
I have a 1977 F350 and it runs on propane. It runs great, and clean I pull a 35ft 5th wheel with it for the last 15 years. I have a 460 engine and it will last me rest of my life. Jim
Old Feb 26, 2006 | 01:02 PM
Phydeaux88's Avatar
Phydeaux88
I do not believe you can run a diesel on pure propane there is no ignition source and the compression ratio is to high
Old Feb 26, 2006 | 02:20 PM
James A. Simpson
My 77 Ford F350 XLT Campers Special-Propane
My truck isn't diesel It's gas or propane and run like a champ.
Jim
deisele75
Alternative Fuels, Hybrids & Mileage
18
Jul 2, 2016 06:12 AM
jonnybronco
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Mar 6, 2014 11:27 PM
blueeyedfordguy
88
Mar 13, 2010 01:53 PM
edselman
43
May 3, 2009 01:23 AM
BBF250
Sep 22, 2005 09:44 PM
