Front end suspension and steering rebuild project.
Old Feb 10, 2006 | 03:10 PM
dale gribble's Avatar
dale gribble
So, it's time to rebuild the front suspension and steering components on my 95 F-150. I thought some of you might benefit from a write up and pictures. If nothing else, I am going to give part numbers that you can save a few minutes without having to research yourself. Pretty much anytime you see a new post from me, there will be an update along with it.
Based on MY experience, I am very happy with Moog R2 (aka Enhanced) suspension parts and have chosen to use Moog parts throughout. I rebuilt a solid axle Dana 44 with these and couldn't believe how beefy the parts were. So, I will be going over the following. If you want any more help or specifics along the way let me know.
Removing 4x4 hubs
Removing front hub bearings
Removing front hub assemblies
Removing spindles
Removing LH/RH axles
Inspecting axle shaft U-Joints- replace as necessary
Removing Tie Rod Ends
Removing Pitman arm **
Replacing Ball Joints
Replacing all steering linkage (except adjustment couplers)
Replacing Pitman arm **
Installing Skyjacker Class II 4" I-Beam drop brackets **
Replacing I-Beam bushings
Installing Skyjacker Class I 4" radius arm drop brackets **
Installing new front springs/daystars **
Replacing Radius arm bushings
Front brakes (rotors turned and pads)
Packing bearings
Installing front steering stabilizer **
** These are optional items associated with putting an aftermarket 4" lift on and can be avoided in stock applications.
and then putting it ALL back together again... Let's keep a frank discussion and stay on topic. We can work through and find the best methods and avoid possible pitfalls along the way. I am hoping by the end we have a comprehensive guide for others to use in years to come.
Old Feb 10, 2006 | 03:20 PM
dale gribble
Part Numbers
Main Drag Link- MOOG DS1138T
Shorter Connecting Link- MOOG DS1017T
RH Tie Rod End- MOOG ES2077RT
LH Tie Rod End- MOOG ES2078LT
Lower Ball Joints- MOOG K8195T (2)
Upper Ball Joints- MOOG K80026 (2)
Axle Pivot Bushings (Revised HD set)- MOOG K8620
Radius Arm Bushings (Thermoplastic)- MOOG K80007*
*I recently replaced my radius arm bushings from the stock rubber units to polyurethane. I was very unhappy with the results. For 1, I actually picked up an irritating squeak when steering and 2, the poly doesn't hold up any better on the RH side due to the proximity of the exhaust. I was surprised to see the poly bushings actually showed breakdown from heat...
I am going to the 'Thermoplastic' set from Moog and will report on that as I go.
I really like these ball joints, not only due to their size, but also because they are greasable! Moog even put the zerks where you can reach them, which is a huge + in my book. I prefer greasable zerks to sealed parts.
I purchased the items through a great online company with the very best prices, and they are even a sponsor of ford-trucks.com!!!! So, click the link from the ford-truck forum so the site can get a few well earned cents for your trouble!
one website, all you need to know-
www.rockauto.com
You can get these parts anywhere from 30-40% off of Kragen and other stores. Great interface, I have used them for years, and I can't say enough about them.
Old Feb 10, 2006 | 03:48 PM
gatesj's Avatar
gatesj
Don't forget spindle bearings and seals and maybe front driveshaft ujoints (transfer case to pumpkin)...
Old Feb 10, 2006 | 03:56 PM
dale gribble
Good point. Bearings and seals will be on an as needed basis. I suspect for me at 91k miles that I will be ok, but there will be a point where the higher mileage guys should really inspect those.
Old Feb 10, 2006 | 03:57 PM
gatesj's Avatar
gatesj
It all depends on how much the hubs have been in, dust, seal deterioration, etc but good point...
zxwut?
34
Sep 23, 2024 10:08 PM
creator
Oct 11, 2016 10:28 AM
vrinner
May 4, 2016 07:30 PM
Z3T3C
19
Aug 13, 2014 03:48 PM
