I Cant Find The Iac Valve!!!!!
Old 02-10-2006, 09:02 AM
mrparle's Avatar
mrparle
mrparle is offline
Unhappy I Cant Find The Iac Valve!!!!!
Can Someone Please Tell Me Where The Idle Air Control Valve Is Located On An 1994 Crown Victoria? And I Need More Info Than Its On The Throttle Body I Need A Picture Or A Good Detailed Step By Step Instructions. Please If You Know Where It Is Please Let Me Know.
I Am About To Pull All My Hair Out!
Old 02-10-2006, 11:34 AM
retired2001's Avatar
retired2001
retired2001 is offline
If you go to the "search" feature on this site and put in "IAC", it will give you a picture of the "IAC" on a 4.0L Explorer. At least it will let you know what you are looking for. Good luck
Old 02-10-2006, 04:28 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
It is burried under the rear of the intake. Looks like a pita to access. Follow the larger hose coming off of the side of the plastic air intake on the drivers side, it should go down behind the intake and lead you to the valve.
Old 02-11-2006, 06:30 AM
mrparle's Avatar
mrparle
mrparle is offline
Smile Thanks
thanks ill try that asap ;O)
2004EXPEDITION4.6L
1997-2006 Expedition & Navigator
07-21-2015 07:27 PM
Daddyo's garage
05-10-2014 09:01 PM
JennifeKillby
13
02-04-2014 09:58 AM
johnskull
1947 and Older Ford Trucks
13
12-10-2013 08:46 PM
Quick Reply: I Cant Find The Iac Valve!!!!!
