I Cant Find The Iac Valve!!!!!
Can Someone Please Tell Me Where The Idle Air Control Valve Is Located On An 1994 Crown Victoria? And I Need More Info Than Its On The Throttle Body I Need A Picture Or A Good Detailed Step By Step Instructions. Please If You Know Where It Is Please Let Me Know.
I Am About To Pull All My Hair Out! |
If you go to the "search" feature on this site and put in "IAC", it will give you a picture of the "IAC" on a 4.0L Explorer. At least it will let you know what you are looking for. Good luck :-X22 :-X25
It is burried under the rear of the intake. Looks like a pita to access. Follow the larger hose coming off of the side of the plastic air intake on the drivers side, it should go down behind the intake and lead you to the valve.
Thanks
thanks ill try that asap ;O)
