What would you recomend
Old Feb 11, 2006 | 07:51 AM
fordtrkpuller's Avatar
fordtrkpuller
FTE *******
I have heard many times by a variety of guys tha the 5 major blades or wicked wheel "Bite" more air than the stock 7 major blades. One of the guys who was telling me this was Shawn at R&S Diesel Performance....but he probably doesnt know what he is talking about.....he only has 3 800+ HP diesel pulling trucks....lol! Jody is cool, great guy and great tuner. I have talked to jody a few times, he is sharp as a tack....but I wonder if he may be mistaken on this one point?
Old Feb 11, 2006 | 08:06 AM
Kwikkordead's Avatar
Kwikkordead
Originally Posted by redneckboy
thats what i was what I was figuring i was going to have to. I was hoping not. budgets suck. Will surg cause harm? I have heard yes I have heard no and i have heard after a long time.
The worst harm that I was going to suffer was from my wife telling me to fix that noise.
Old Feb 11, 2006 | 08:12 AM
Kwikkordead
Originally Posted by jtharvey
Kwik, not to disagree, but how do you mean bite the air better? I was talking to Jody at DP earlier this week (when I was ordering my chip , and it showed up in about 3 days ) I told him about what my turbo plans are with the 1.15 exhaust and ATS intake. I asked him about the WW and he said that the stock compressor wheel actuallly flows more air than the WW, which would lead me to think that the stock one "bites" the air better. Maybe we're on the same page, just in different languages.
But, the WW still does sound cooler and is the cheapest way to eliminate the damaging surge.
We are on the same page. I put in the WW before the guages, so I can't give you any boost numbers that I may have gathered. All I can tell you is my surge was cured with it, even if it did cost me a couple of LB of boost.
Old Feb 11, 2006 | 08:52 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
my take on this subject is that since the wicked wheel has only 5 large blades, the vacuum pulls more air into the space between the back of the previous blade and the "biting edge" of the blade in front of it. this is what i believe cures surge, and the 5 smaller blades help move that air. with the stock wheel having 10 equally spaced blades, it is more effective at moving air at the lower boost levels. i think this because at lower boost, there is less vacuum in the intake pipe, thus meaning that less air is sucked into the space between the blades per revolution. more blades= more air pumped. once you speed the turbo up to a certain speed, the time for the air to shoot between the blades is less, which makes me think that less air can be pumped at higher turbo speeds. the WW has half the amount of blades that "bite" the air, so this makes me think that there should be twice the amount of time for the air to be allowed to shoot between the tips of the blades. to me, this makes sense that it eliminates surge, because the positive displacement of the turbocharger keeps the air flowing out of the nozzle and not back through the compressor shroud, due to the fact of not being able to keep sucking air in and pushing it out.
make sense?
Old Feb 11, 2006 | 08:59 AM
fordtrkpuller
FTE *******
My wicked wheel makes 27-28 lbs of boost with a Banks big hoss and a 6-gun tuner on a 7.3 PSD. It moves air in sick ways.
Old Feb 11, 2006 | 10:03 AM
Kwikkordead
make sense?
It would be interesting to have a camera pointing at the intake during a time of stall. I would fully expect to see the same sort of fogging that happens on the tops of fighter jet wings when they pull a high G turn.
Old Feb 11, 2006 | 11:03 AM
jtharvey's Avatar
jtharvey
Glad we're on the same page. And, an intake camera would be nice to see. I doubt it would be that tough to rig something up.
Old Feb 11, 2006 | 11:14 AM
jtharvey's Avatar
jtharvey
my take ...with the stock wheel having 10 equally spaced blades, it is more effective at moving air at the lower boost levels...once you speed the turbo up to a certain speed, the time for the air to shoot between the blades is less, which makes me think that less air can be pumped at higher turbo speeds
Your explanation has good logic behind it, but I don't necessarily agree with this statement about the stock wheel pumping less air at higher turbo speeds. Look at how many fins are on a jet engine's intake fan. They're packed in there tight, and all of the same size and shape too.
Old Feb 11, 2006 | 11:19 AM
jtharvey's Avatar
jtharvey
Well, if we're going to compare numbers , my stock wheel can easily see 30+ lbs of boost, and has been on the edge of 35 lbs several times. This with a Predator (85hp tune loaded) and a Banks 6-Gun. Injectors are stock and fuel system only has the Hutch mod done. Well, it did at that time anyway.
I usually try to keep it under 25 lbs though, at least until my new turbo goodies get here.
