need some help with 4 wheel drive
Old Feb 28, 2006 | 06:27 AM
47studebaker's Avatar
47studebaker
help
Can I assume that I have a 1356 TC ? If so is the cam spring # 33 in the diagram http://i48.photobucket.com/albums/f2.../bw1356_p1.jpg
Thanks for your help.
Old Feb 28, 2006 | 03:24 PM
witdog2020's Avatar
witdog2020
No, the spring actually sits under the motor, in the small diagram, its the little round coil spring. The big piece under the motor is the cam, the part under it is the spring, then there is a rod that slide through the center of both, and is all pressed together.
Is this something you will be repairing on your own?
Old Feb 28, 2006 | 03:45 PM
47studebaker
Help
Probably not. I don't mind swaping TC or shift motors but FI, carbs and other parts but there are many repairs i leave to the professionals.
Old Mar 1, 2006 | 11:50 AM
witdog2020's Avatar
witdog2020
Then you may be better off to see what it would cost for a rebuild or good used T/C. Where abouts you located?
Old Mar 2, 2006 | 07:06 PM
47studebaker
help
Im in north central PA. Ill contact my local trans rebuilder, I was told he also does TC. Ill also see if I can return this TC, it was only in 45 days.
darickh
1978 - 1996 Big Bronco
26
Sep 2, 2011 05:24 AM
mengonij
Nov 16, 2009 10:26 AM
fordtruckboyf150
Sep 5, 2007 08:15 PM
Wild Karrde
Mar 17, 2007 07:57 AM
