Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Finding vacuum leaks...???
Old Dec 10, 2002 | 10:15 PM
Pilgrim's Avatar
Pilgrim
I remember hearing a really good way(simple) to find vacuum leaks but can't remember what it was. Anyone know what it was? (I'm working on a 91 Ranger that seems to have a vacuum leak but can't find it.)
Old Dec 11, 2002 | 02:44 AM
Torque1st's Avatar
Torque1st
Posting Legend
You can use a propane torch (without the flame) to throw some enrichment gas at specific suspect locations. To get the most fuel gas to the location you want try blocking the air intake ports on the torch. When you direct gas at the leak the engine will change rpm. Use only in a well ventilated area and watch for open flames. Careful!!!
Thanks for using FTE!
[font color=red]As a Moderator I do not "Subscribe" to most topics,
please send email/pm if you need a reply -Thanks![/font]
Old Dec 11, 2002 | 07:03 AM
wabiker's Avatar
wabiker
Actually what I found was to take that propane bottle, unscrew the flared fitting with the little holes, add a length of rubber hose of the small diameter and a one of those vacuum line splice connector (small orifice...then youve got better direction and concentrated flow...And last but not least, remember propane is lighter than air so start at the top and work your way down...
....Or ya could just go buy a can of carb cleaner....
Old Dec 11, 2002 | 01:26 PM
Buckarcher's Avatar
Buckarcher
Old Dec 18, 2002 | 02:57 PM
hawk's Avatar
hawk
wd-40
Old Dec 19, 2002 | 07:18 PM
V10KLZZ71S's Avatar
V10KLZZ71S
carb cleaner or similar aresol spray works for me,just be careful.
Old Dec 23, 2002 | 03:23 PM
edenroadmaster's Avatar
edenroadmaster
wabiker,
propane is heavier than air.
i usually dont nit-pick other's posts, but this is a safety issue.
I hauled bulk propane for 4yrs, and have seen my friends lose eyebrows, get burned, and been thrown 20ft by an explosion.
luckily nothing serious has happened to me, i just got freeze burned once. liquid propane is -43 degrees F, and if you get in contact with it, will actually"burn"you by freezing your skin.
respectfully yours,
eden
Old Dec 23, 2002 | 03:35 PM
Torque1st's Avatar
Torque1st
Posting Legend
Thanks Eden!
